disable mac-locking
disable mac-locking
Description
Disables MAC locking globally on the switch.
Syntax Description
Default
MAC locking is disabled by default.
Usage Guidelines
If you disable MAC locking globally, you cannot enable MAC locking on a specific port.
The following example disables MAC locking on the switch.
disable mac-locking
This command was first available in ExtremeXOS 15.7.1.
Platform Availability
